Vehicle starts up great. Idles very smoothly until it warms up. In drive, car shakes and is rough. In Reverse, car is worse than drive. Sometimes the vehicle is smoother when warm than other times. In park, not as rough, but still a little rough.
1) Intake Manifold gasket replaced to upgraded version from mechanic.
2) MAF cleaned 2X
3) Throttle body cleaned as well
4) No CEL
5) Plugs replaced and properly torqued
Car runs great on highway, gas mileage is pretty good. What concerns me is the following below.
1) First mechanic stated that idle is too low from diagnostic equipment, and it is probably the idle speed motor. OEM is around $900 with labor, but he could not guarantee the fix, so he told me to drive the car, enjoy it and call it a day . Also, he stated the motor and transmission mounts are fine and the car will run just fine.
2) Yesterday, I took this to another recommended shop, and he stated that the engine is fine, it appears that there are no misfires or vacuum leaks, and the motor and transmission mounts need replacing and this is the problem. A total of $550 out the door with like-kind OEM quality. I have not priced out OEM, but this concerns me with aftermarket parts. I have to go back to the mechanic and he has a smoke machine and will look at possible vacuum leaks as well.
After running the car for a while, sometimes at a light, the engine seems very smooth (for 30-60 seconds) at most. If the mounts were bad, then should this not be a problem all the time?
If the mounts were bad, should this not be a problem when idling over 1,000 RPM's. Upon start up, the car is very smooth. The colder the weather, the smoother, the idle. Only issue is when fully warmed up.
As mentioned previously, the car runs great. I would rather rule out everything else but the mounts first. There have been so many horror stories that mounts have been replaced, with and without OEM parts only to leave the shop with the same chronic problem. The only issue is the minor inconvenience at a stop light. Usually not in traffic as I drive the vehicle off traffic times. Because this is not the my only vehicle, I am not overly concerned, but would like to fix this as I do like having a spare vehicle. Also, I do not just want to start swapping out parts either as this is not a feasible option. If the car in fact is idling too low, then I can deal with this as it never has stalled out, but the rough idle.
The car is in a good state of tune, and someone mentioned the following:
Vibrations from a low idle is a common problem with 2005+ 9th gen Corolla, first ones with DBW... There never was a required ECU recalibration available, and idle speed cannot be adjusted. There's no point spending to try to 'fix' it. It'll run fine as long as it's in a good state of tun
2) MAF cleaned 2X
4) No CEL
