Blocks striped and out of the bay so I cant use axle or subframe for bracing. My typical method went out the window with that... Im thinking 19mm extractor socket, left handed drill bit, then if all else fails ill pull out the angle grinder and pray. The balancers trash so It doesn't need to be pretty more important that the crank stays intact.
Im aware of a few homemade tools floating on the threads however im a one man team and I simply do not have strength/weight needed to break the bolt and provide counter weight so I've been hesitant on making any of the tools. My impact isn't strong enough.
Is there no SST or back yard tool that simply holds the balancer in place without the need for a counter wrench/weight so I can use my breaker bar easily ?
