Ruthenium Spark Plugs?
1 reading
4.4K views 12 replies 6 participants last post by  JohnGD
NGK came out with ruthenium spark plugs a couple years back. Though the website says they improve engine efficiency and spark ignition, they don't make any mention to improvement in mileage:
Ruthenium HX™ Spark Plugs - NGK Spark Plugs
I checked YouTube and google, but didn't find any before and after mpg results with using them compared to iridium spark plugs.
Does anyone have experience with changes in mpg with ruthenium spark plugs?
Thanks
On my turbo VW, the NGK iridium IX mileage went down after 20,000 miles. The ECU was also tuned as well. So, the ruthenium HX kept on chugging along
for a 1zz, where the cylinder pressures are not that high compared to a turbo running 20 pounds of boost, the Ruthenium HX vs Denso Iridium Twin Tips? I’d get the ones that are less expensive
#5 · (Edited)
I don't know if this information can really help. But if you're replacing spark plugs. Check RockAuto's website, I like to use Denso or NGK parts a lot.
I bought NGK Ruthenium plugs. I wanted to give it a try the reviews I read around seemed positive. I read a lot of things about counterfeit parts being sold on Amazon and eBay so I ended up price-matching with Advanced Auto Parts. Feel free to give it a shot if you feel comfortable trying these plugs. If you don't want to try these plugs I would just stick with whatever originally came with the car. Probably some sort of Denso plug.
And to be honest with you. I don't notice anything different. I was just curious to try them because my spark plugs were due. I would say it maybe felt smoother for a day. But I feel like any new spark plug compared to an old one would make a difference slightly. My gas mileage is still the same. The only thing I can really think of that might be an advantage for the plug is the claim it's made out of a harder material "Ruthenium". So it could possibly end up lasting longer but at the time when I was researching about the plug. I couldn't find any long-term reviews anywhere so I don't know if the claim is necessarily true only time will tell. Buying this plug was more of an experimental thing for me. I was just really curious to try it for some odd reason. If this plug isn't something you want to try I just recommend going with the OEM plugs normally. I don't know the exact part number but it's generally some sort of Denso plug. I think I currently only have 15K miles on them and I don't have any complaints. Best of luck though.
I'm going try NGK Ruthenium next time. The price is about the same as NGK Laser Iridium anyway. Double check part number on NGK's e-catalog and use Rockauto's 5% discount code.
Modern engines are so well tuned there probably isn't going to be noticeable power increase. I'll see if there's smoother idle (which some reviews claimed) and maybe peppier acceleration (maybe not the same degree going from nickle/copper to iridium-ix with the thin center electrode).
You are most likely right I don't think you would notice a power increase. I personally never noticed a smoother idle but I noticed the acceleration was better for maybe a day but I didn't feel like a massive difference for me. Felt like it was the same as the old plugs the next morning. I got the DFE-designed plugs for my car not sure if users feel anything different for the PSPE-designed plugs.
This post has been deleted
