No difference in CA fuel injector wires on 5s-fe.
In a sense, the injector control wire can be looked at like a garden hose with a trigger type hose nozzle on the end. Water pressure is in the hose as long as the trigger grip is closed. That is analogous to your 12 volts when the scope signal is high. When you pull the trigger grip on the hose, the water pressure releases and a stream of water flows out. In the fuel injector, a transistor acts like the spray valve on the hose end. An electronic signal goes to the transistor inside the ECU. This signal is just a voltage pulse. It turns the transistor on, or causes it to allow current to flow, just like the garden hose nozzle lets water come out when the trigger is pulled. The thing to understand here is that when the electric current turns on in the injector control wire, that current charges the injector coil, making a magnetic field ... just a magnet ...that opens a small valve opening in the injector, letting a measured amount of fuel into the cylinder, at just the right instant of time.
