Posted from TTORA. Looks very nice, I think it turned out great, better then I thought it would.:thumbup:
No, the holes are an option for guys who are going to add a set of PIAA's. The skid plate pictured is also an option. Price is a little high starting at $979 + any options you want but like anything you get what you pay for.cddallara said:Is it just me, or can you use factory fogs??? Looks good, IMO.
Looks like a slightly better approach angle, shackle mounts and personal preference.stuckTaco said:Close the gap between the bumper, fender and lower headlight trim. Put my name on the waiting list.
I do have one question though. What make this better/on par with ARB's?
Also spots for some PIAA's.BillBrasky said:Looks like a slightly better approach angle, shackle mounts and personal preference.
I'm pretty sure that gap is set so the bumper can flex a bit and not F up the fenders. The ARB does the same.stuckTaco said:Close the gap between the bumper, fender and lower headlight trim. Put my name on the waiting list.
Like SilverStreak05 pointed out the gaps are to allow for flex when winching, also if they lowered the headlight hoops anymore they would interfere with the headlights. What's better? Well like BB said it's really about preference. I really like the better approach angle and the recovery points on the shrock. Those are the two biggest and they are nice. You can also customize the bumper to the way you want, hoops, no hoops, extra light tabs etc that's also nice. What I don't like is the 4" light holes standard, it kinda forces you to go buy 4" aftermarket lights unless you want two big holes in your bumper.stuckTaco said:Close the gap between the bumper, fender and lower headlight trim. Put my name on the waiting list.
Both bumpers are around 100+ lbs, add a winch and you're looking at another 60-90lbs. Heavy duty coils and shocks are a must to compensate for the added weight, with the stock coils the front would drop probably 1-1.5" and the stock shocks wouldn't control the weight very well. With my coilovers I don't really notice much of a difference handling wise, a little but not a ton. Without them though the nose dive and reduced handling would be a lot more noticable. The biggest difference I have noticed with my truck is braking, I've added a lot of weight though. If you're looking at a bumper like the Shrockworks or ARB though you're obviously not building a sportscar, everything is relevant especially when you add heavy armor to your truck.va beach taco said:How much do either one of these bumpers weigh?
Is it enough weight to lower the front of the truck any?
Does the weight cause any change in handling and/or ride?
Thanks
thas the one u gonna get with all the mob blood money.Pb said:I think they can also make one from Stainless Steel, but it would be crazy expensive.
stuckTaco said:I like to know what gauge steel they are using.
Noodle frame you should say then too, it's not only the bumper it's the frame flexing as well when winching forces are applied, besides these are not trying to win ya no beauty contest. If the bumper is too rigid they can cause damage to the frame when in a minor impact, conversly, a bumper that is too flimsy (like the stock crap) won't provide adequate protection during a more substantial impact, say bye bye to your truck should you hit an animal while in say Baja. Your truck won't get far with a mashed in rad and cooling system.stuckTaco said:Noodle bumpers, more gap so it can flex. If the bumper is going to flex this much. I'll stick to my stock one and take it easy on the trails.
