Single click/clunk turning wheel extreme left or right
1.4K views 3 replies 4 participants last post by  nme7
2013 Highlander, base AWD 3.5 L engine, 165k
I did quite a bit of work on my car and it’s driving well except for this annoying loud click/clunk when I turn the wheel extreme left or right while turning. I’m not sure but it may also be clicking when I stop sometimes.
I have replaced the following:
The passenger side front caliper, both front rotors, and pads, The struts, sway bar links, lower control arms, both axles, the left outer tie-rod end(I damaged it). I did not replace the passenger side tie rod end as it was not damaged.
I had the car aligned and it’s driving well.
I’m not sure what’s causing this loud clunking sound, but I am worried as this is the first time I’ve done suspension stuff.
Help appreciated!
Do you feel it in the steering wheel? If so, it could be the intermediate steering shaft. Very common on Highlanders and other Toyota models from that time frame. The grease that lubricates the splines dries out and causes the telescoping shaft to catch instead of sliding smoothly. Supposedly it is just an annoyance and not a failure risk. You could replace the shaft if you want. There are various folks on YouTube who claim to be able to fix it temporarily by injecting oil past the rubber boot in the footwell using a hypodermic needle. Never tried that myself. I've just lived with it.
I would also go with ISS. If not that, then maybe the clock spring. I would also say the stabilizer links, but since you've replaced them it is unlikely to be bad.
If you do go with ISS, I would recommend getting the OEM part. They upgraded the ISS and so far nobody has reported issues with the redesign. It is easy to replace. I was able to access it through the front left wheel well, with the wheel taken off. Then contorting my body to get access to the bolt that is in the driver's foot area. Injecting grease into the old ISS is only a temporary solution and the clunk will return.
