SMD vs LED light bulb upgrades
6K views 5 replies 5 participants last post by  animatronic
Just thought anybody who is thinking of upgrading to LED light bulbs in your dashboard and around the vehicle use T5 and T10 for most applications and a 31mm festoon bulb for the overhead courtesy light. I tried both SMD & LED bulbs and found that SMD are way brighter especially if you use other colors than white (mine are all red). LED though satisfactory is much dimmer and cheaper compared to SMD. When doing the switch to LED both SMD & LED draw much less power you will have to get a new signal light relay flasher use a CF13JL-02 for LED or your blinkers will be way too fast! Later dudes...:thumbsup:
