I very recently replaced the exhaust gasket between the exhaust manifold and front pipe to seal a leak at that flange. Prior to this repair, all the smog readiness indicators in the Bluedriver scan tool showed the tests were incomplete. After driving a little bit, all the smog readiness indicators are good except 'Catalyst Vehicle' - see image below.
Per an acquaintance who is a mechanic (but doesn't do inspections) here in NY state, if only one test related to smog readiness is incomplete and there is no CEL (there is not), then the vehicle will pass emissions.
Thoughts on this? What exactly is the 'Catalyst Vehicle' check looking for? The O2 sensor check is good, and the downstream O2 sensor is downstream of the exhaust gasket I replaced, so that suggests to me the repair stopped the leak.
