Stalling The Engine With Seafoam
3.9K views 7 replies 7 participants last post by  MR-355-5sfTe
Alright, so I'm currently in the process of doing the SeaFoarm engine treatment. I very slowly poured it through the brake booster line and the first time it didn't smoke too much. So I'm doing it again and its smoking more before I've even finished putting all of it in.
So I'm letting it sit and reading the little pamphlet that came with the SeaFoarm. Its says once the engine has returned to idle, pour enough seafoarm into the engine as directred to stall (stop) it. Won't this hydrolock my engine and pretty much kill it?
So far ive just been very very slowly pouring it into the line and the idle has dropped from time to time but I have not put enough in to stall it out or anything. Or should I be stalling it out? I really don't want to hydrolock my car cause it would be detremental, and imput would be great. TIA
Safer to pour it.
One guy on yotatech dropped the PCV hose into the can of seafoam and wound up busting a rod and bending another. (along with the associated pins) after his 5vz-fe sucked the entire can near instantly.
Someone else lurking on here asked me a week or two ago how to unflood an i4 after doing the same thing.
So you definately want to pour it.
You have an i4. Put a funnel on a PCV/or BB line, pour a 2/3 of a cup into the funnel. Don't do it slowly, or you won't achive anything. Too fast and you might flood it out (hydro-lock it no... flood it, yes) As soon as the 2/3 of a cup is in the engine it needs to be cut off, and sit for 5 min.
This will pull SEA FOAM down on top of the pistons and to the back of the intake valves to dissolve carbon. Turn ignition off. Restart engine after 5 minutes.
have someone rev it and they can also turn your car off real quick... your engine should be completely warm otherwise hydrolock has a much larger chance of occuring. feed it sips of seafoam and while someone is holding your rev at about 2,000rpm and keeping it there. don't pour enough so your motor stalls... you want to turn your motor off manually (may sputter out after you turn off the ignition, covering the vacuum line with your finger or reconnecting helps it die). for more info about seafoam do a search, there are a couple seafoam threads on TN.
This is crazy, think about it, you're risking an expensive engine on a $5 product with a convoluted application procedure.
Try AutoRX, you just dump it in with your oil change and change the oil in 1500 miles and your done. It'll dillute all of the engine crud safely. I haven't heard of any catastrophic events happened by it's users either. I've had it in my truck for a week and it already stopped the serious oil leak.
