I have a 1993 Toyota Corolla with a low millage (JDM) engine (obd1) in it. I've replaced almost everything and it's sort of like a brand new engine. Many of the sensors I've replaced because I've been stabbing in the dark trying to figure out why the car keeps hesitating, cuts out, when being driven. It's like a very short hiccup that won't go away. Sometimes it does it more. Sometimes it does it less. It does it more when the engine is cold. It's not extreme enough to trigger an engine code. The last thing I did was replace the throttle control module. I put a Denso on it because it seemed that the aftermarket one didn't adjust to the specs that it was supposed to be and it still "hiccuped". To adjust it I bought the plug and connected to my multi meter. I've tried it at all different settings within the range of what the book says for the first and third wires. Still no luck.
Here is a VIDEO I made so you can listen to the problem:
Also, ever since this problem started, almost a year ago now, my gas mileage is down about 4-5 mpg.
The other thing it does is poor, irregular idle. (Yes, I've replaced the idle air control valve - with an aftermarket.) When I did replace the idle air control valve, that fixed the fast idle problem but didn't fix the irregular idle speed. Now I wonder if I should have bought a OEM? The more the engine warms up though, the cleaner the idle speed but I know there's still something wrong. Yes, I've cleaned the throttle body out. Is there anything else on the throttle body that can be fixed or replaced?
Here is a list of everything that's been done under the hood and elsewhere:
Replaced parts and labor:
I have an extra set of injectors available. (From the JDM manifold. They haven’t been cleaned.)
Some of the things I’ve done made a difference in how well the engine runs and others did not. I’m still having the “cutting out” problem.
93 Toyota Corolla 1.8 7AFE
- Low mileage Japanese domestic motor (JDM) - replaced two years ago. (Belts, front and rear seals, oil pump, fuel filter, air filter, plugs, wires, radiator, etc.)
- New exhaust sensor. Toyota OEM.
- New knock sensor. Toyota OEM. (Plug does not snap. Just pushes on.)
- New coolant temperature sensor. Toyota OEM.
- New fuel pump. Advance Auto. (There was no gunk in the bottom of the gas tank – clean.)
- Tried a different computer. Bought one used on Ebay. Didn’t make a difference.
- New catalytic converter.
- New distributor. Budget from Amazon. (When timed to 10 degrees, it’s turned far to one side for some reason.)
- New engine mounts. Old ones were fried. Engine was shaking.
- New struts and sway bar end links.
- Fairly new battery & alternator. (Two years old. I’ve noticed that the rear windows are slow to roll up and down… Low power?)
- New exhaust manifold. (Old one was cracked.)
- Intake manifold cleaned out.
- Replaced original idle control sensor with aftermarket part because Toyota's is $250!
- Tried a new throttle control sensor (Toyota OEM) and have adjusted it to different spots to no avail.
- Ran one bottle of Sea Foam through the gas tank about two months ago. Beyond that the injectors have not been cleaned.
