This is not Toyota’s fault. This is a shop’s fault.
That is the view from under the passenger side wheel well. Note the gap between the subframe and the chassis. Recently I had taken my car to a shop I won’t name to get my clutch replaced with an Exedy Stage 1 clutch and Fidanza 7.5lb flywheel. I chose this shop because the owner owns a supercharged Elise, however it was his employees who were working on the car. I was going to take it back in a couple days to get the axle replaced under part warranty after the CV boot had torn after just 800 miles. My XRS has 225 miles, the bushings are torn up, so there’s an expected clunk. However since the boot had torn, the clunk got extremely worse. I figured the axle was starting to wobble around, so I jacked the car up by the subframe to check. I rocked the wheel, and heard nothing. I stopped using the car for work and only used it to grab groceries. I’m about to leave for a trip, so I decide to take it to one last meet before I leave, and I’ll drop the car off before I go to the airport. As I’m leaving the meet, I decide the axle is going to be replaced anyway, and just the boot is torn so I decide to to a pull. Floor it, wait about 10 minutes, hit lift, hit 2nd gear, thud which I assumed was a bushing noise, and go to make a right turn. As soon as I turn the steering wheel, it feels like an arcade racer game with no coins in, and the car isn’t turning. I stop the car in the middle of the road, with no way to turn it off the road. Luckily there was no traffic. I thought maybe a tie rod had snapped, but both my wheels were perfectly straight, and neither were turning. I look under the steering wheel, and my steering shaft had become disconnected from the input shaft of the steering rack. The steering shaft doesn’t move up and down, so there’s no way to bring it up to get it back in place. I call the help of my buddies, and with the two cars stopped in the middle of the road with hazards, this attracts the help of a cop and a mobile mechanic. Cop coned off the lane for us since we were unable to turn, and while my buddy was finding a way to get the steering connected, the mobile mechanic is inspecting the suspension, and notices the subframe bolt is missing, and the subframe has dropped about an inch. This caused the rack to drop, and pull itself free of the steering shaft. If this had happened on the highway, it could have been fatal. I didn’t hit anything or get hurt, just stopped slowly. I message the shop and I am quite furious at this point, since they dropped the subframe to do the clutch. The rattle/thud I was hearing was the subframe hitting the chassis. They are going to tow the car, replace everything (bolts, clockspring, axle, anything else) and align it free of charge. Pretty shitty experience but it’s getting taken care of at least.
TL;DR Shop did clutch and didn’t torque subframe bolts, subframe dropped and pulled steering rack while driving, lost steering.
