Tailgate TSB Question
1.7K views 12 replies 8 participants last post by  Rodge
This is for all of those who actually had their tail gate bend and had the TSB done. How bad was the dent and where did the tailgate actually get screwed up.
I'm asking because I was originally going to take my truck to the dealer to have their bodyshop give me an estimate for Uhaul because of the incident I had with the tow dolly. Well, my buddy came over today to unload my spare 86 axle. He positioned the axle over the tailgate and then bent down to grab it. He stepped onto the tailgate and I watched the tailgate bend down and thought I heard a popping sound. Sure enough when I closed the tail gate there was a crease running down the center of the tail gate from top to bottom. It's not visible until you look at it on a certain angle, but I know it wasn't there until today.
Oh yeah, my buddy said he weights about 250, and the axle probably weighs close to a 100. So it only took 350LBS to bend it. That's pretty pathetic if you ask me.
Mine bent right in the middle (loaded snowmachene, and yes, we used wide ramps). There were no crease, but the gate itself was "bowl"-shaped. After I took off black plastic trim on the top edge, I found that TOP lip was cracked. I bet if you take off your trim piece, you'll find the same crack. It radiated from the square holes where the trim snaps into, to the outside edge.
Well I just looked at it again. The trim piece up top is slightly bowed out. I noticed the bowl shape of the tailgate on the passenger side after I noticed the trim piece being bowed out. It's not noticable unless you look at it on the right angle.
I've had enough hassle with my service manager, I can just imagine how much I'm going to have to fight to get them to get this done. Either way my tail gate's getting repaired. Either by the TSB or UHaul's insurance. I'd rather the TSB get done. If it bent out that easily I can't imagine what's going to happen when I start using my truck more frequently to haul parts and stuff around now that I have a dedicated trail rig. I'd hate to see what would happen if I loaded up my spare 22RE in the back of my truck. :eek:
Get a Gater Saver. Well worth the money. Seth might have some left over from his last build.
I would but I'm currently only dumping money into my 4Runner. I want it up and wheelable by Takeover in July. 3-day weekend of wheeling. :D
I had my tailgate replaced per the TSB. Though it seemed heavier to open and close, after I removed the liner to put on a tailgate lock I must say that the braces look very wimpy and it probably will bend again. :thumbdown A fork lift bent mine when it lowered a strap of bricks into the bed. It made the tailgate have a half moon shape from the inside, but no visable damage from the outside. Hope this helps.
#13 ·
Well I took it into the dealer today. Unfortunately for me, they, the body shop guys, need to talk it over with corporate Toyota due to the other damage to the tail gate. I told the guy, that per the TSB, the entire tail gate gets replaced.
He said "I see, but, I still have to check since this is the first one I'm doing". It sounds like they're going to do the work under warranty but want to get the "OK" from Toyota before they proceed any further.
Seth:
I sent you an email. And for some reason, Outlook auto corrected Rodge to Ridge. :lol:
