:sosad: I'm not sure, but it's highly likely I'll have to rebuild my engine or swap it out... My ES250 (stick) has developed a bit of a nasty rod tap.
So here are my options:
1. Rebuild the current 2vzfe engine. Cost $700-$1500
2. Aquire JDM 1vzfe 2.0l V6 and drop it in. Cost $550-$800
3. Swap in 3sfe or 3sgte. Cost $450 up
I'm seriously considering a 3sfe transplant for these reasons:
1. Fuel economy, all my 3sfe Camrys averaged around 30+MPG both of my Lexus get around 23-25MPG with the 2vzfe and the power difference doesn't seem all that much.
2. Donor vehicle readily available for 3sfe ECU, wiring harness, axles and mounts, as I have a 88 Camry parts car (stick).
3. Overall cost of getting replacement parts ect.
So anybody think this is a dumb idea? I realize that the fuel economy isn't going be be quite as good as a 3sfe Camry but it should be a marked improvement.
Now for the technical questions:
1. If I do this, would I be able to mount the 3sfe to the manual transaxle already in the car?
2. When I swap in the ECU and 3sfe wiring harness, will there be any issues with the ABS, Cruise Control, Tach or other electircal systems?
3. Should I also swap out the exhaust system, or can I use the current exaust?
Opinions & expert advise please!
