Alright its in and works great. Few things from install to help others
Using this:
http://www.amazon.com/Kenson-Electr...r_1_1?s=electronics&ie=UTF8&qid=1443229065&sr=1-1&keywords=shark+fin+fm+antenna
-Comes with a 17' extension cable, ending in a standard large radio plug. Had about 3' left over after I ran the wire to the radio.
-Does not come with a long wire for the built in pre-amp
-Threaded shaft that goes through the roof is 12mm OD. You could use a a 31/64" drill bit if you want, that's only a hundredth bigger, however if you use a more common 1/2" bit, you'll have 3 hundredth of play and it won't be a tight fit. You should get the proper 12mm drill bit.
-It comes with a single nut. I got a 12mm washer and split lock washer to secure it. I also used threadlocker.
Stuff that's gotta come off to drop the headliner...
-So D-pillar panels need to come off completely (you can hang them by the seat belt). To do that the main side trunk panels need to be partially removed. Start from the back and work forward. Remove all fasteners from the strut towers back (including the ones hidden by the cover over the struts, and directly above it). It will be a very tight fit, but you should be able to get the d-pillar panels off to get the headliner down.
-Below each rear AC vents will be a small 1.5"x1.5" plastic cap on the roof. Behind the cap there will be a 10mm bolts. Remove them.
-AC vents are attached to headliner, leave them alone.
-Remove the middle roof light if you need too.
-Remove the rear trunk light. Take lens off (2 indention on the front to pry it off). If your looking at it, it will appear like a rectangle. If you draw a square in the middle, the outer left and right sides have a cover on them that pop off. Behind that there will be a clip you pull back to pop the light free of the roof.
There are 3 of these connectors:
1 on each side of the trunk light and one right in the middle of the trunk, remove it.
So once you drop the roof liner this is what your looking at
There is a a lot of stuff on the roof blocking access to the actual top sheet of steel. There is only a 4"x6" area where you have direct access to the roof itself. Its right in front of the trunk light, above a bunch of wires. To get better access you can move the wires out of the way by removing the 2 bolts highlighted on the right.
It will look like this once you drop it
Just to help visualize where the hole is, here is another picture.
I couldn't figure out a good way to describe this, so I drew the best drawing ever made in MS paint. So the hinges for the tailgate mount on a flat area that's about 2" below the actual roof line. There is a rise to the actual roof. My measurements were referenced from this rise. The hole was about 6.5" forward of that rise to clear all the stuff to get to that opening in the roof I showed above.
BTW don't cheap out on drill bits. This is a couple dollar 12mm one on amazon, I simply got it to drill this 1 hole. I drilled it and it snapped immediately after (as the reviews said it would, didn't believe it). Sad when a 12mm bit snaps drilling through 18gauge steel... :lol:
Painted both sides of the hole to prevent rust on exposed metal:
Broke out black silicon, DON'T use their ULTRA silicon, that's not meant for painted surfaces.
First thing I did was take the cover off (and paint it), but I also put a bead of silicon just inside of where the cover meets the rubber to help seal the unit up. Also put it over the screws to seal the screw openings.
Also put a bead around the threaded rod to seal around the opening. I also put it just inside of the rubber seal to help seal it to the body. There is an air opening on the back to vent moisture. Left that exposed.
Mounted it. Added washer, lock washer, and threadlocker. Note you will need a 2nd set of hands here. Someone is going to have to hold the antenna while you tighten from below. I didn't get it as tight as I wanted as the person couldn't hold it tight enough to keep it from spinning....
Got it on and was sitting a little to close to my roof rack, was actually hurting reception.
Moved the rack forward solved everything (and for those who said my crossbars would get stuck in place from rust way back when...nope
And final pics of antenna on.
Now for running the wiring, I suggest running it along the passenger side roof and down that A-pillar. You can simply tuck the wires along the roof by pulling the weather stripping down from the door openings. Just make sure you get it deep enough to clear the curtain airbags. A coat hanger or long flexible rod can help pull/push wires where you hands won't reach.
Leaving next Saturday for a trip so will see what long range reception is like then.
