Do you all rotate your tires every 5k miles? I change my oil myself but then have to take my truck to have the tires rotated. Is this what other people do or do some of you rotate the tires yourselves?
Yea i rotate my tires every 5k, when i go and buy my next set from costco i'll get free rotation.1st_Cavalry said:I rotate my tire by myself(every 5k).I don't bother rotating the spare though as stated in the manual...But the manual will tell you how your suppose to rotate them.I believe fronts go straight back, and the rears go to the front, but crossed?
That's how it's done!SJlittlefoot said:Yea i rotate my tires every 5k, when i go and buy my next set from costco i'll get free rotation.
I dunno about the manual but i go front diagonal back and back straight forward, that to me makes the most sense wear wise, and thats how i've always rotated my tires.
Got the torque wrench, just not a floor jack or jack stands. Seems like a saw a set at Sears containing both...any certain weight I need in a floor jack?TACOSALAD said:I personally use a lift at work, if not, I'd use jack stands. Also, I'd get a torque wrench, lugs should be at 80 foot pounds.
I use jack stands, ALWAYS use jack stands. I use to do it one at a time using the spare tire as a temp bolt in while i move each tire around. but now i use four jack stands, MUCH quicker and i don't have to drop the spare.Volrus said:For someone who has never rotated his own tires, what tools are required other than the standard tire changing tools (jack, tire iron, etc.)? Do you guys use jack stands or ramps? Do you jack the truck completely up and take off the wheels or do you do two at a time? Maybe someone can give me a brief "how to"?
Not really, if they are selling it in a set with floor jacks, it will certainly be fine. Just be careful where you place it, in the back, lift from the pumkin, in the front, make sure you don't lift from the oil pan.Volrus said:Got the torque wrench, just not a floor jack or jack stands. Seems like a saw a set at Sears containing both...any certain weight I need in a floor jack?
I would do this too if I didn't already change my own oil. My main reason for changing the oil myself is time savings, but if I have to still go somewhere to get my tires rotated, I'm not saving any time.06 trd dc taco said:I payed 25$ for life time rotation well worth the money for me
yea i believe i save time too when i rotate my own tires and change my own oil. Actually any mantainence i can do myself i will, gives me peace of mind that it was done the right way for sure.Volrus said:I would do this too if I didn't already change my own oil. My main reason for changing the oil myself is time savings, but if I have to still go somewhere to get my tires rotated, I'm not saving any time.
How can you get by with just two jack stands?SJlittlefoot said:I use jack stands, ALWAYS use jack stands. I use to do it one at a time using the spare tire as a temp bolt in while i move each tire around. but now i use four jack stands, MUCH quicker and i don't have to drop the spare.
Tools:
jack tools from the truck
SUV floor jack (makes things easier but you can use the bottle jack included with your truck)
Jack Stands, i say four but you can get by with two.
Strong back, those tires get effin heavy
jack stands for one end, floor jack for the otherVolrus said:How can you get by with just two jack stands?
Same as I have always done... end result is same as owner's manual method, each tire spends time at each position.SJlittlefoot said:i go front diagonal back and back straight forward, that to me makes the most sense wear wise, and thats how i've always rotated my tires.
amp2oo1 is right, i did that on a friends car when he only had two jack stands. Jack up the rear, jack stand the rear, remove tires, jack up the front rotate tires, (you don't even need a floor jack you can jack up one front side at a time with a bottle jack, seems unstable though), lower vehicle.Volrus said:How can you get by with just two jack stands?
Good point, and I should add that I never get under a vehicle without jackstands. I do, however, change tires using a floor jack only -- and I don't get under the vehicle for that.fireman9170 said:Ive been on a few calls, where people didnt use jack stands. One died, the others I guarantee will use them from now on.
That theory surfaced some 35 years ago, when radials were first being suggested for American cars. The idea was that a radial would take a 'set' during use, and reversing its rotation could cause it to destroy itself -- or at least suffer a shortened life. Whether there was any truth to that is debatable, but at any rate, it does not apply today -- nor has it for many years.05silvertaco said:I understand it's not good to change rotation on a radial tire.
A 13/16" sparkplug socket fits perfectly. :thumbup:05silvertaco said:You'll also need the correct size 6 point by 1/2" socket
