Tokico 1.25 drop ???
1.2K views 7 replies 4 participants last post by  Venom_5
Looking around to get some struts, I found this:
HP SERIES SHOCK, STRUT, FRONT, RIGHT, SOLD INDIVIDUALLY -- NON-ADJUSTABLE -- 1.25" Drop, For Performance Enthusiasts Looking For The Best In Handling And Ride Quality, The HP Series Damping Shows Tokico's Valving Flexibility Providing A Smooth Comfortable Ride At Lower Speeds And Greatly Increases Control And Handling At Medium And Higher Speeds, Completes Any Suspension Upgrade That Includes Lowering Springs And Larger Diameter Wheel And Tire Combinations.
So the HP SERIES struts lower the car 1.25 with the original springs ??????
So if I put the eibach's it will drop the car more than with the KYB gr2's ??????
the springs are supposed to push upward on the car, which is why having shorter or different rate springs allow lowering
the struts shouldnt really serve the same function - they are just there as a damper so you dont bounce infinitely as if you were on springs alone
IN europe they cut the bottom part of the strut (were the spring seats) and they lowered as close to the wheel as possible to lower the car. I thought that maybe Tokico does that, or maybe where the struts attaches in the bottom the support it's welded higher to lower the strut.
