A couple weeks ago I took my 6th gen (3-speed auto, A131L) onto the highway, 65+ mph and I noticed it started unlocking the torque converter while cruising. It normally used to stay locked up over 45mph unless I really floored it. I had let the car sit for several months while I was out of town several months ago, but I didn't notice any problems before 2 weeks ago. While on the highway I could see the tachometer fluctuate as the torque converter was trying to lock up and unlock.
I checked the ATF level with engine warm and running after shifting slowly through all gears and back to Park. It seemed a low, between cold and hot marks, so I added a little ATF. I didn't want to add too much because I didn't notice any leaking. Maybe I should check the coolant for signs of ATF getting in through the cooler, but the radiator is only a few years old. Anyway, the problem persists, and it takes a little longer to shift from 2nd to 3rd even if I'm accelerating slowly.
I believe the lock-up torque converter is purely mechanical, using some sort of governor to control it.
Is there anything else I should check before I just add more ATF, or recheck the level better? The cable from the throttle seems to be intact.
It shifts from 1st to 2nd fine and accelerates up to 40mph normally. I'm hoping this isn't the whole transmission failing!
