Torque spec for the Long bolt at the engine/ subframe to body..>?
1 reading
1.6K views 3 replies 2 participants last post by  Luc
Hello, Anyone chime in whats the torque spec for the long bolts for the engine to subframe & body.? I have mix results, my haynes says 133ft lbs. But online have seen somewhere like 85ft lbs. These are 10.9 grade long bolts. The smaller ones that go on the triangle brackets are 24ft lbs i blv. Appreciate. Thanks
The diagram came straight out of a PDF version of the service manual. Initially, I thought it was 172 ft-lb, but that's for the control arm, but 107 ft-lb looks to be the correct value. However, your picture looks like you're working on the RX350 since RAV4.3's 2GR-FE does NOT have a power steering pulley and the undercarriage panel clip points to the bumper are different on the RAV4.3.
