Transmission need replacing at 103000 miles..
3.1K views 24 replies 16 participants last post by  tedsarr
I took my 2019 toyota camry LE ..I took it in for oil change since i had just got back from a trip from California to Louisiana and back to California ..no issue doing the drive... however the dealer said i need anew transmission ..the car drive normal no shifting issue no issue other i did notice a low winding noise driving locally ..the fluid has never been change and the dealler suggest it not be change now as it may accerate the issue but they asking 12 grand to replace the transmission.. i took it to a local transmission shop and they heard the low winding sound and said that the transmission will evently need to be replace but that it can last a long while before that point he also suggest not replacing the fliud since had never been replace..but his price was about 9 grand but he also said he would have to order the replacement transmission from the dealer and it will most like be on 2 to 3 month back order and that it would be a remanufactor one at best... are othe folk seeing these transmission fail at 100000 miles as well..
I would also be leery of these opinions to replace. The noise you mention can also come from uneven tire wear or a wheel bearing. For a major component to be replaced, be darn sure it needs to. With only 100k on the odometer, I too suggest changing the trans fluid. If it is a bearing (or something else) in the transmission, I would keep driving until more apparent/major.
used trannys, i.e. ticking time bombs? $5k is a lot to spend if you only get another 100k miles out of it. I'm not being snarky, just trying to find the best option here. I have a Camry with 110k on it and it's exhibiting trans failure signs. Is there a certain year of used 8th gen trans that have fewer problems/more time before failure?
I am there right now. I'm experiencing a loud whine coming from under the battery. I also experienced the car buck a few times with moderate acceleration. I have the car parked now until I figure out what I'm going to do. If the whine is coming from under the battery then there's a good chance your trans is dying. I have a cold start thread here with video of my whine if you want to compare. My car has 111,000 miles on it.
#9 ·
I know this is off-topic (apology in advance) but man... there are not just a few threads about these 8 speed automatics failing - this keeps coming up. In an apples-to-oranges comparison with the 2018-2024 Camry Hybrid P710 eCVT vs the 2018-2024 non hybrid transmission, it doesn't even seem comparable. There just isn't any posts about the current Toyota eCVTs blowing up.
The fact that the Dealer - supplied replacement OEM transmission is on "back-order" isn't a good sign either.
I'm coming from the old school Aisin A750F in my Taco; which has been bullet-proof for 390,000 km. These new (non-hybrid) ones just seem.... weak.
owns 2023 Toyota Camry XSE Hybrid
Reactions: madeuce
#13 ·
I just posted about my 62,000 mile, 2019 Camry with an eight speed transmission that needs replacement. Dealer is no help since it is out of warranty as someone mentioned with the transmissions being backordered obviously, they are a problem. After 15 minutes of driving, it does work OK. I did change the fluid which did not really help a point on spending around 5000 for a rebuild of it. I am also thinking of a class action suit. This is ridiculous with so many people having issues with their transmission.
#22 ·
what makes you say that's BS? I work in the auto industry and unfortunately the dlr and the trans shop are probably right. I usually don't like to side with the dealer but in some cars i've seen it 50/50 it helps and hurts like your throwing money down the drain.
#21 ·
$12000 - No! A Scam and avoid that aforementioned "mechanic." On my 1999 Camry, the trans finally failed at 235000 miles. Likely because the previous owner was always speeding. Maybe keep an eye on the fluid level and keep running. If it gets worse, than something's going on. Beware of scam mechanics out there - they are common!
#23 ·
unfortunately, that's how much the stealership charges. the 8th gen isn't the same trans in the 99's its an 8-speed and the whole notion of not changing the tranny fluid is a scam. The "lifetime" fluid is the reason why were seeing a lot of early failures around 100-130K miles. the ones that fail before that are the outliers and the exception not the norm. Those who replace the fluid on a schedule for the first 50-60k and then every 15-30k thereafter are the ones I've seen make it 200K+ miles.
