Ok after doing some research the first mod I will maek to my camry will probably be a RSB.
As far as I can tell there are two choices: Whiteline and TRD.
Whiteline runs about $109, TRD runs about $150 but is adjustable.
From pics I see the TRD has 2 holes in each end. So I assume the way you adjust it is by reattaching it to the holes that are farther from the end for "race."
Now I am thinking the RSB will even out the handling a bit (Reduce understeer). But Eventually I can see myself gettign a Front sway bar, which would skew the car more towards understeer gain.
Which makes me think that the TRD bar woud be the most useful. I would buy it, install it in the street setting, and drive it around. Then when I buy the FSB (probably from whiteline) I would set the RSB to race to try to keep the balance less on the understeer side,
Does this make sense? The TRD is like having 2 sway bars in one. You can simply adjust it if you need more stiffness in the rear, for example when you install a thicker front sway bar.
