This issue started back during warmer weather and seemed to taper off as fall came into full effect. Engine has to crank and crank to start but will eventually turn over and run. Once up to temp it seems to run relatively normal. When in park it idles at around 1200 but drops to 700-800 when in drive and will bog down when coming to a stop at red lights. The cold weather (~low 30's) seems to also be making it worse as it runs better when its warmer out. Replaced spark plugs, coil packs, air filter and ran sea foam to try and determine if there was a carbon buildup issue. Finally replaced the throttle body as it seemed to point to a TPS issue. The only moment that seemed to improve how the car ran at all was after the spark plugs were changed. Fuel efficiency seems to have suffered slightly which now leads me to think that the O2 sensors are the culprit.
Heres the list of codes:
P0300 - Random Multiple Misfire detected
P0303 - Cylinder 3 Misfire Detected
P0304 - Cylinder 4 Misfire Detected
P0420 - Catalyst System Efficiency Below Threshold Bank 1
C1201 - Engine Control System Malfunction
C1241 - Low or High Power Supply Voltage
C1246 - Master Cylinder Pressure Sensor
Any thoughts?
Any thoughts?
