Trouble with 92 camry turn signal
1.3K views 3 replies 2 participants last post by  Piledriver
EDIT: The turn signal wasn't working, and one of the hazard lights didn't work. It turns out it was a damaged wire
And they lived happily ever after
Hey guys, I was giving it some thought, and here's what I understand:
It has to be one of the following:
- Bulb (bulb works in other socket, so this isn't it)
- Flasher (hazard works, so eliminated)
- Fuses (checked, they're OK)
- Wiring
Since wiring is the only one not eliminated, that must be the problem. I guess I'll just take it to a mechanic so they can figure out what and where, hopefully it won't cost me too much
did you try the driver side bulb in the passenger side socket? i had a similar occurance where i got into an accident and the driver side bumper turn signal stopped working immediately, then all of the sudden it worked. this happened on and off with the bulb working for a long time then suddenly it would stop working. i simply replaced the bulb and viola. everything was taken care of.
