hey guys just concerned about my turbo... its on a shelf in my room and i routinely drip oil into the oil feed hole and give it a spin once in awhile to keep it wet and for fun, hehe...
but i noticed that oil must be pooling up in the exhaust turbine side cause if i stand it on end oil leaks out....
im affraid if its pressurized oil then i will have bigger problems.
i rebuilt this turbo and know that there is a metal snap/ring at the base of the turbine shaft and has a dime sized gap when not in the bearing cartridge but when i slide it into place, i do feel a snap ...
turbo has no outta spec shaft play, radial or axel
is there a problem or is there no problem?
