Check out this video link. What are your immediate thoughts? Sounds like a bad ticking. Tried to listen around to identify the source, but cannot tell upper, lower or an accessory. Added footnote, the check engine light is also on for a misfire on cylinder 3 and 2. Engine runs smooth at idle and under load, but has this bad ticking. I did the rudimentary pull-the-plug-to-see-what-happens for cylinders 3 and 2 individually, and the engine idle changed as it should, but the sound was no better or worse. Thoughts?
link to noisy engine video
