Update on the 93 V6 Camry SE 5MT
1.7K views 17 replies 8 participants last post by  Stuckinthe90s
Recently got her back after having a trusted toyota shop look her over and ended up doing the 3 injectors under the plenum. Plus all spark plugs. I also did hood struts, a new windshield reservoir and pump + some SEALIGHT LED headlights + resistor harnesses. Next up is gonna be a bluetooth unit + new antenna and speakers and eventually a repaint to Dark Emerald Pearl.
#5 · (Edited)
Great car! I had the exact same spec except a 92 SE 5 speed in green, bought new. Mine had a J VIN made in Japan. Always regretted trading it in.
I had the obligatory 90's smoky bubble sunroof vent installed up top though, although don't see it in this picture I found. Pretty dirty from the high Sierra winter and snow which is where I lived then in NV.
I recently found an old car magazine I'd saved from 92 or 93 with a good comparo between the Camry SE, Taurus SHO and Maxima. If I stumble across it again I'll post it here.
I did an engine flush with liqui moly. I refilled and ran with napa 5w-30 full synthetic and a motor craft filter for 15 min. I drained and refilled with Rotella T6 5w-30 multi vehicle and a napa gold filter. I also did the AFM mod and leaned it out 4 clicks, which improved my idle, and throttle response noticably.
#17 ·
That is correct, it was only used on the Solara (Gen1, which still shared the Camry Gen3 underbody).
If you don't have access to a used one from a Gen 1 Solara, or don't want to buy one from the dealer, you can make your own out of 3.2mm thick steel (1/8" thick), with two 14mm holes drilled 90mm apart.
the Gen4 Camry had similar, but the holes are much further apart
