Hello! I have a 2007 1ZZFE Corolla and I buyed DENSO (234-9052) upstream oxygen sensor from ebay... the connector doesn't fit , like it is too tight ... what do you recommend? is there something I can try before requesting a return?
If it's just not snapping together sometimes the rubber seal gets dry and wants to bind up when you're re-connecting them. Some silicone grease rubbed on a paperclip and then rubbed around the rubber seal inside the connector will usually get them to go back together that last little bit so it snaps.
You'll find that trick coming in handy lots of other places around the car as well, it also helps to further weatherproof the connection by adding some highly water resistant schmoo.
Related Threads
Toyota Forum
posts
6.4M
members
660K
Since
2001
ToyotaNation Forum is a community dedicated to all Toyota models. Come discuss the Camry, Tacoma, Highlander, 4Runner, Rav4, Corolla, Rav4 Prime and more!
