If you're going to use the power port for a windshield-mounted device, check this out & keep your dash plugins for other dash-mounted or hand-held devices.. Naponal DashCam 7Pin Rear-view Mirror Power Adapter & Connecto7r Important: You must have a power connected, auto-dimming mirror, otherwise the adapter cannot be installed. Carefully check the number of pins & the exact configuration of your car's auto-dimming mirror connector plugin power port B-4 ordering. • This adaptor ("dongle") allows you to tap 12v power from the female rear power port plug of your 2nd Gen Highlander's auto-dimming rear-view mirror. • Convenient & easy-access USB plugin connectors are both suitable for any type compatible dashcam, mirror camera, GPS, radar detector, aftermarket TPMS monitors, sonar parking assist monitors & other similar USB-A wired devices, etc. • Will not work with devices requiring 12V power through an RCA-type plug in connector. • This Naponal Adapter allows simple plug & play installation. • Adapter helps keep most wires perfectly hidden above & behind the rear-view mirror. • No unnecessary installation cables or unsightly connecting wires hanging down from above to distract from driving safely & otherwise be in your field of vision.. • Adapter kit includes (2) 5V2A max USB charging adapters with your choice of using one or both. • (1) 5" USB micro, mini & type-c charger cable are also included. • I have included several photos to help see what it looks like on & behind the back side of my 2010 Toyota Highlander Hybrid mirror with my windshield-mounted Garmin Mini 2 DashCam connected to the Toyota OEM auto-dimming rear-view mirror • Photos of the windshield area behind the mirror B-4 & after installation are to show you what it looked like during installation process.
