I have a base '06 Matrix that had an upgrade to the C60 six-speed transmission by the previous owner. I started a clutch replacement and we found that the aluminum for the rear engine mount had broken off the transaxle casing:
Looking around, I found a C59 transmission on a Pontiac Vibe in a local pick/pull yard. Here's my main question: can the bell housing on a C59 be used on a C60 transmission? From what I can tell, and from every transmission diagram I can find for the Matrix, they're the same and that the only difference is the 6th gear added for the XRS. If I can just pull the bell housing off the donor, that's what I'll do. I'm not too excited about going back to the five speed and then potentially having to replace the transmission again.
