How is a compression test performed on bank 2 (firewall side) of a transversally mounted v6 when the spark plugs are only reachable when the intake and other components are removed?
OK. The question remains but for bank 1. How is the compression checked when the air intakes are removed to access the bank 1 spark plugs. thx.Bank 1 is always on the left side of the engine on a V6. Therefore Bank 1 is the firewall side and Bank 2 is closest to the front bumper on a transversely mounted engine.
I have looked many times for reference to my question and your answer is the first that addressed the issue.You will still get a reading when the engine is cranked. You do know you must disable the fuel and ignition system to perform the test.
If you are unsure of the procedure there are an infinite number of videos on the subject.
Oh okay, so you're just curious then. Nothing wrong with that.I haven't had problems with the hybrid system but it's different than non-hybrid and always have to be aware and wonder when there's issues is the hybrid system part of the issue or not. The vehicle has been very reliable...but it's a toyota so that's normal. I've never had a mechanic work on the vehicle, but the body shop has had a go at it. (daughter driving). The benefit of a hybrid, if any, is the improved gas mileage compared to non-hybrid...warm weigher 25 mpg and winter 20 mpg.
