Sorry for bumping an almost 6 months old thread, I'm also looking for the vacuum hose sizes.
I tried twice to get measurements with my caliper but I'm getting mixed results lol
6mm ID/10mm OD on TB end and 8mm ID/12mm OD on VSV end (2mm thick) - EVAP from TB to VSV (molded hose? maybe use a 6mm/8mm adapter?)
8mm ID - 12mm OD (2mm thick) | VSV EVAP, same as above?
8mm ID - 14mm OD (3mm thick) | Air cleaner EVAP
3/8" ID - 5/8" OD (0.12"/3mm thick) | PCV valve to intake manifold (seems to match SAE better than metric)
12mm ID - 17mm OD (2.5mm thick) | Large vacuum hose on from the intake manifold to the brake booster
And how about the smaller vacuum hoses? I didn't measure those, are they 3mm ID and 7MM OD (2mm thick?)
Thanks guys
Edit: I digged more through Airtex's sale drawing and confirmed the following I.D. (All two place decimals ± 0.015)
EGR vacuum solenoid (25860-74050)
0.15" - 3.8 mm
PCV valve (12204-74030)
0.37" - 9.4 mm
EGR vacuum modulator valve (25870-74090)
0.16" - 4.06 mm "R" and "P"
0.25" - 6.35 mm "Q" and bottom
Vacumm regulator valve (90925-03193, purple colored, where's this located?)
0.18" - 4.57 mm (x2)
Purge valve solenoid (90910-12271)
0.15" - 3.8 mm
0.16" - 4.06 mm (x2)
Vapor canister solenoid (90910-12264 - at charcoal canister)
0.25" - 6.35 mm
