Valve adjustment question
474 views 4 replies 3 participants last post by  DCM
91 22RE
I started adjusting valve clearance way back when I had a VW Karmann Ghia. The question is, why do we have to adjust them hot? And yes, I know everything expands when hot. I've got one loose lifter after adjustment.
I looked on YouTube, one pro-shop adjusts to the same clearance cold!
I think the factory service manual is confusing on this issue. Here's what it says for the 22RE:
The FSM clearly state "Cold" but the HINT says warm it up. To me, it sounds like it you should warm it up, so everything sets, and then adjust the valves cold. Setting them hot doesn't make any sense because by the time you get to the last valve, the engine has gotten colder.
Setting them cold is just to get you in the ballpark, if the engine has been rebuilt / the valve train disassembled. Then warm it up, and readjust to spec.
LOL no, the engine will not cool off by the time you do the last adjustment, unless you are unbelievably incompetent and slow.
