Does anyone know if this would be possible? I have a friend with an '06 Avalon with 20" wheels on it, and he asked me about putting bigger brakes on it.
that....makes no sense. bigger wheels wont wear out your brakes any faster than smaller wheels unless your buddy has been much more aggressive braking.
bigger brakes isnt solution. you need more durable pads. get ceramic pads. about oem performance but lasts longer.
this is exactly right, I doubt venza, highlander and the models that offer 19 - 20" on premium models have different brakes when
looking at base model VS limited or platinum trims.
I have a hard time believing a +1" or +2" sidewall variation would cause even the slightest difference in brake pad wear. I would check rockauto.com for some Akebono premium ceramic pads, or do the "lifetime warranty" deal at a local big box corner parts store and just keep changing them.
I would maybe suggest looking for a vehicle specific big brake upgrade not a "swap" those 2 cars dont really share anything.
if looking for a discernable difference I'd do the pads I mentioned above, slap on 2 sets of drilled rotors (again, see rockauto.com ), take the calipers apart and clean and lube the caliper pins with specific grease, do a brake fluid flush or pump a boatload of fresh fluid through the system. I'd bet this simple service with improved rotors and pads would be more than adequate on a 06 Avalon. the Avalon is the flagship toyota sedan, I doubt it would take much to get it stopping good !!!
the premium drilled are the way to go without getting the roughness that slotted will produce. see below.
http://www.rockauto.com/en/moreinfo.php?pk=1626702&cc=1432837&jsn=492
http://www.rockauto.com/en/moreinfo.php?pk=877918&cc=1432837&jsn=561
bigger brakes isnt solution. you need more durable pads. get ceramic pads. about oem performance but lasts longer.I agree with you on this. I autocross and have been known to drive pretty aggressive sometimes. But he came up to me and said that he wanted bigger brakes, so I'm looking into seeing if it can be done. I would like to talk him into this instead, but he has his mind made up, so I'm gonna make it happen.this is exactly right, I doubt venza, highlander and the models that offer 19 - 20" on premium models have different brakes when
