My 99 camry has about 30 psi compression on all 4 cylinders. History: Put a new timing belt, tensioner, spring, etc on about 6 months ago. ran good but always noisey. Started running rough, CEL indicates missfire on all cyl, if I remember correctly. rechecked timing belt and I think it was off a tooth. Went back through EVERYTHING timing wise and I am sure it is timed correctly now, however, it would not start. Looked like plugs were oil fouled. Ran a compression test and all cyl. are about 30 PSI. Added a slight bit of oil, and didnt change. Also, may have overheated at some point, not sure because someone else was driving it. Any idea what I'm looking at? Still not timed right? Head gasket? Any ideas will be greatly appreciated.
