Hello Forum
Need help figuring out a vibration issue that started a little over a month ago. My 2018 Camry SE would vibrate a little on the highway and slowly go worse to were I could feel it at a lower speed of 40 mph. I took it into a local shop where they replaced the suspension and struts, did an alignment and then balanced the tires. While the majority of the vibration is gone, but when I get on the highway, there is a wobbling noise and the faster I drive the more there is. What do you think I should try next? I spent $2600 so far with this previous fix. I read somewhere that a frame shop can pinpoint the issue but wonder if anyone has had the same experience and knew what the issue could be. Appreciate anyone's help.
Jim
Jim
