Hello, all.
I just finished a 260 mile trip from Flagstaff to Las Vegas for a conference I am attending. As I started the trip with only 430 miles on the new '16 Tacoma Limited 4x4, I was constantly varying the speeds driven, per the manual, which says to do this for the first 1000 miles. Unfortunately, I came away from the trip with numb hands and lower arms. I noticed that at speeds approaching and over 70mph, there is a distinct 'buzz' in the steering wheel. The wheel does not shimmy or shake and the vehicle tracks true when you let it go; however, the buzz is always there. At 65-70, it is only lightly noticeable; however, if you grip the wheel tightly, you can feel it. At 75-80, it literally became uncomfortable for me after a while. It seems to intensify on shifts from the 6th to the 5th overdrive gear as the vehicle RPM rises with the shift (the truck does this a lot to maintain speeds, even on slight incline grades). I also felt that I could distinctly feel it in the footwell. At a full stop with the vehicle in neutral, I could raise the RPM and not feel anything at all.
My first step is to take it to the dealer to have them check the balance on the tires; however, I am puzzled that, if is a tire balance issue, why would it intensify on a downshift? Why no shimmy or shake at all in the steering wheel, just the transmitted buzz?
I have read nothing either here or over at TacomaWorld.com that anyone else has experienced anything similar. My FJC worked hard at 80mph; however, there was never any buzz at all like this in the steering wheel and foot well (and, for that matter, I've never experienced this on any other vehicle like this...I've had tires out of balance but always got a slight shimmy/shake to go with it).
In the back of my mind, I'm concerned that this is a transmitted buzz from the engine caused by something allowing it to transmit up the steering column; however, admit that I might be over thinking this and it is all a tire problem...
Any comments or input is appreciated. I have to be honest and say that, if this is not fixable, I could not continue to drive this truck, as I take several long trips on freeways at 75-80mph and could not handle the numbness/discomfort from the issue.
I certainly don't recall feeling anything of the kind on my test drives; however, even though I got up to 75-80 on those drives, they weren't long enough for me to have truly noticed this....
