Warning ⚠️ lights
1.2K views 8 replies 4 participants last post by  Dommy
My 2020 Camry SE have the LDA malfunction, Drive- start malfunction, Second brake malfunction, rear light and check engine lights on what could be the problem.
NB: my mechanic made me change my battery, ECM and Fan but still am facing the same issue. The car runs ok, it says engine no faults
#4 · (Edited)
Some 2020 Camrys had an ECU issue that would cause the battery to drain and could cause error lights. This TSB might help, print it out and bring it to your dealer to check.
Some 2020 Camry's had an ECU issue that would cause the battery to drain and could cause error lights. This TSB might help, print it out and bring it to your dealer to check.
Thank you so much bro, I really appreciate 🙏
