If anyone is planning on putting lowering springs for the Venza onto their 2nd gen, beware that it will only fit 08-10 pre-facelift models unless you put Venza or pre-facelift struts up front.
The facelift 2010-2013 models have a single counter-clockwise spring on the front passenger side which will not be compatible with the standard clockwise spring strut. This was discovered when someone attempted to put 2010-2013 Bilstein B6 struts on their pre-facelift car.
Photos are from my 2014 RX350 (same front suspension as 2010-2013 Highlander) and from some random Venza I found in a parking lot.
Facelift setup:
Front passenger side
Front driver’s side
Venza / Pre-facelift setup:
Front driver’s side
Facelift setup:
Front driver’s side
Front driver’s side
