It started a few weeks back. Maybe once or twice a drive (30-60mins)(19-40miles) I would sometimes try to accelerate from a stop and I would get a sputter lasting a few seconds. USually when I was trying to beat a car on a turn. Not the best time for that to happen... after a couple sputters the engine would produce regular power and things would be business as usual. Now after it warms up every 5-10 seconds while idling in gear(R or D) I'll get the same sputter and rpms will drop by 100 or so. enough to the point where that vacuum valve on the side of the throttle body will lose enough vacuum to buck the little wheel holding the drive by wire and boost rpms back up. Along with that under light acceleration it will go find however if I try and give it some extra gas it starts to sputter for a continuous few seconds until full power kicks back in. Even if I try and floor it through the sputter it actually seems to get worse. I'll speed up slowly and the times vary but it will eventually stat getting full power again and return to normal conditions until the next time I try to accelerate. Currently I have no codes due to resetting the battery after cleaning the spark plugs but after I drive again tonight on the free way im sure i;ll get codes to pop and i'll post them but until then does anyone have a clue on what it might be? I'm assuing its dealing with my ignition system but it came out of no where so im not sure what it migt be
I guess it might help but it seemed to start when I tried replacing 2 of the spark plugs with different types but I wasnt able to get the other 2 due to that rubber boot on the end of the plug wires coming off inside the spark plug tube. Preventing me from being able to get a socket around the plugs...I'm now missing 3 out of 4 of those rubber boots. COuld tht be effecting my spark delivery that much? I also did clean out the fuel filter days prior. It seemed to run fine after doing that though problem occurred days after doing this so it didn't raise alarm. I also took my intake hose and box out to clean the thottle body in the process.Im sure it is all hooked up correctly though...
2000 toyota camry solara 5sfe No after market parks except o2 sensor which arent plugged in and havent been since possession of vehicle for some reason when a/f is hooked up the car drinks gasoline like alcoholic on good cocaine
