I believe all cars run rich at start but this one strongly smells of gasoline on start: are there some checks I can do to figure out if it's within limits?
Also, in general, what can running to rich on start be a symptom of?
The TB, while greasy, is not dirty (so as to obstruct air flow) but there seems to be a leak around the TB (noise of air being sucked in around the area, specifically where the plastic housing meets the TB)
I was thinking, perhaps this leak is directly responsible for the rich condition, but discussing with a friend pointed out the error: with air leaking in, the mixture would be lean, not rich.
Note that the sound is in the TB after the filter and sensor, so the sensor is likely reading an air volume that is less than what finally ends up in the intake (due to the leak)
