2008 HL Limited V6 AWD, 203k miles. Second owner and chief grease slinger.
sky, I've been doing ATF changes on my own vehicles for several years now and can say from experience that the amount drained will vary pretty widely depending upon type of vehicle, make of transmission, type/age of ATF, transmission temperature, ambient temperature and interval from last run. That is, let the vehicle sit overnight and you will get more drained fluid vs. letting it sit just a few minutes.
Also, I have noted that if you pop the trans into reverse for a few seconds before shutting down, you will get more ATF drained. Maybe someone can tell me why this happens; I only know it does.
Just FYI, I just did a drain and fill on Tuesday on my HL. I got 4.5 quarts out. I replaced with 4.5 quarts and the level came to dead-nuts-on at hot level on the dipstick after a 20-minute drive.
All the best, Haya....
