I just purchased an '07 Avalon Touring. I just wondered what type of antifreeze coolant I should purchase for this. I notice that the red type is already in there now, but I wanted to get some input on this. Any suggestions? Thanks so much.
http://www.waterandmorehub.com/deionized-water-vs-distilled-water/*Deionized water is deeply demineralized, ultrapure water with the resistivity close to 18 megohm-cm. It is used in microelectronics, printed circuit boards, instrument manufacture, pharmacy, washing liquids, etc.
In order to obtain the high quality pure deionized water, a multi-stage water purification process can be used. After pre-cleaning, the water is supplied to the reverse osmosis membrane, and then the water is filtered through a special deionization medium, which removes the rest of the ions in the water. The purity of deionized water can exceed the purity of distilled water.
Thanks for posting the links.I've seen no difference in the performance of an antifreeze when comparing distilled or deionized water. I've used both and typically will run my own homemade double distilled water. The quality of either purchased varies plenty and is a mute point since the quality of either is usually not stated. I just don't use or recommend tap or city water.
So, feel free to do a 50:50 mix with your full strength EG when mixing your antifreeze/coolant.
Some of these are available full strength and others are already 50:50. When draining the block/radiator/bottle, any should give you 5 years of usage, which is considerable better than Toyota's 2yr Red and equivalent to the overpriced 5yr Pink.
http://www.amsoil.com/shop/by-produ...other-products/antifreeze/passenger-car-and-light-truck-antifreeze-and-coolant/
http://www.pentosin.net/f_antifreeze.asp
