What wheel offset ????
1 reading
28K views 7 replies 6 participants last post by  shaner18_725
I have a 94 Extended cab 4X4 going in the shop soon for a Rough Country suspension lift. I'm going with 33 x 12.5 x 15 tires and am deciding what rims to go with. I'm also putting on Bushwacker extend-a-fender flares. I'm unsure of what offset I should order when ordering my rims. I'm going with a 10" wide rim. The rims I'm thinking about are pro comp and are listed as -46 offset. Will these work in my application ? There doesn't appear to be much option but would like to know from you guys ... the experts !
Thk's :cool:
The offset of a vehicle's wheel is the distance between the centerline of the wheel and the plane of the hub-mounting surface of the wheel. It can thus be either positive or negative, and is typically measured in millimeters. Offset has a significant effect on many elements of a vehicle's suspension, including suspension geometry, clearance between the tire and suspension elements, the scrub radius of the steering system, and visually, the width of the wheel faces relative to the car's bodywork.
Zero Offset - The plane of the hub mounting surface is even with the centerline of the wheel.
Positive Offset - The plane of the hub mounting surface is shifted from the centerline toward the front or outside of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative Offset - The plane of the hub mounting surface is toward the back or brake side of the wheel's centerline.
"Deep dish" wheels typically have negative offset or a very low positive offset.
To maintain handling characteristics and avoid undue loads on bushings and ball joints, the car manufacturer's original offset should be maintained when choosing new wheels unless there are overriding clearance issues.
Wheels are usually stamped with their offset using the German prefix "ET", meaning "Einpresstiefe" or, literally, "insertion depth". An example would be "ET45" for a 45mm offset.
Calculating the offset of a wheel is a fairly easy mathematical equation. First, measure the overall width of the wheel (remember, just because a wheel is 18x7.5, does not mean that the OVERALL width is 7.5”. It means that the measurement between the outboard flange and the inboard flange is 7.5”). Next, divide that width of the wheel by two; this will give you the centerline of the wheel.
Overall width/2 = Centerline
After determining the centerline, measure from the hub-mounting surface of the hub to the edge of the inboard flange (if the wheel were laying flat on the ground – face up – your measurement would be from the ground to the hub-mounting surface). This is your back spacing.
Back spacing - Centerline = Offset
I believe 4 inch bracket lifts like that call for wheels with <3.75" backspacing. That's -1.25" offset on a 10" wide rim, or -.25" offset on an 8" wide rim. I have American racing outlaw II 15x10s that have about 4" backspacing with 33x12.5s on them, but they still work no problems (had a little rub on the valence, but nothing major)
