Whats the highest miles you experienced with original transmission fluid?
4.4K views 11 replies 9 participants last post by  kathyricks
Hello I'm doing this for personal statistics I'm very curious whats the highest miles with original trans fluid . Here is bit history about me
I owned old camry with over 300k trans flushed at 115k besides that nothing killed it by putting lucas trans fix after a minor slippage otherwise i prob still be driving it. .Now I got a 18 camry with sealed and i'm stuck in dilema of i ever should touch the transmission. I seen camrys lexuses fords subarus went over 260k miles 15 plus years with original fluid.My new camry owner manual says not to touch it unless needed under certain driving conditions etc. So I'm honestly leaning towards not ever touching it Whats do you guys think any of you drive high mileage cars with original atf fluid??? please comment!!!
i
Put some Lucas in it and see the result, LOL.?
Seriously now, this was already debated here. Search the forum for it.
Opinion differs from owner to owner.
I plan to service mine at 80k kms. The dealer should do the service upon request but say it`s unnecessary.
Gears are gears, clutches are clutches - they wear!
I commute 2 hours worth of highway driving a day for the 11 or so years I owned it. Only things other than brakes, tires, engine oil, that I remember doing was a TSB or so, one was for a software update for transmission shifting shortly after I bought it new. The week before trading it in the ac stopped blowing cold. Rear main seal dripped a bit too at the end. When it was time for a new car I really didn’t feel like getting another Camry, but it made the best sense so I did. I’m not sure how many other cars would have been as reliable. They gave $500 trade in :) lol. I didn’t end up buying extended warranty on the new 2018-I figure I won’t need it. I used synthetic engine oil the entire life of the 2007.
I did a poor mans flush a few times on my 05 camry 2.4L. The first was at 166k miles along with filter and pan cleanout(unknown if it was ever changed), then again a few more times. (All using Valvoline Maxlife Synthetic)
It has 305k miles on it now. Not sure about the longevity of the tranny because it has had a wierd 1st-2nd shift problem since I got it at 166k. (Valve body probably needs a sonnax zip kit)
But, it's still the original. (U250E)
#9 ·
Transmission isn't sealed. Its dipstickless since the IQ of the average owner in the last 50 years has dropped and doesn't know how to use a dipstick. It still has drain/fill plugs and a overflow tube for level checking when the ATF is at the proper temperature.
Driving style has much to do with transmission longevity. Maintenance helps but is not the end all.
Reading the dipstick correctly is the problem. Modern transmission fluid must be read at an exact temperature as determined by the manufacturer. Each manufacturer has their own temp range. In the old days you checked it when it was hot, and that was it. I think Toyota is 103 degrees is the temperature to check the fluid, not hotter or cooler. On my Ford truck it's 190 degrees. If you checked a Toyota at a Ford temperature it would read overfilled. Check a Ford at the Toyota's temperature it would read low. Best way to prevent that from happening is to remove the dipstick to keep the owner from tampering with the fluid. The transmission is filled by a computer at the factory to an exact amount by volume. And I know plenty of people who have high mileage vehicles and never changed the transmission fluid.
On the 6 and 8 speeds the fluid runs 20 degrees hotter in normal driving than the old 4 speeds and accumulates more wear debris because of all the extra gear shifting. So the fluid is already browish by 35,000 miles and is black and starting to get sludgy by 100-125,000 miles. So I drain & refill the pan 3 times in quick succession it every 30,000 miles to change out a majority of the old fluid by 125,000 miles
