My 2008 2.4l Camry was running fine, until I decided to do a wheel alignment last week at 72k miles at local Mineke. After wheel alignment on the way back, I can feel the steering was loose. Also at low speeds if I turn my steering wheel 80% to the right and then leave it, then it turns again to right instead of turning back to center. Same happens on left turns too. Also while driving I can feel the steering is not perfect as before.
So today I took it back to the shop and they told me after test drive that, my rack and pinion has to be replaced for a cost of $800.
Is it really rack and pinion problem or an alignment issue?
Attaching the alignment sheet.
My tires are all good with no uneven wear and also has plenty of thread left. Wheel alignment was done as preventive maintenance, which I regret. Power steering flush was done by myself at 70K miles.
Sent from AutoGuide.com Free App
