As part of a complete rebuild of a '92 Camry XLE 2.2L A140 automatic transmission, I'm replacing the torque converter with a reman one. But I have no idea which brand to get. It seems like every auto parts retailer sells a different brand, which I assume are often the same as other brands with only the names changed, what with so much consolidation in the auto parts industry.
I'm not looking or anything high end as this is my mom's car and she doesn't drive it that often, fast or for long distances. Just something reliable with a good reputation that's not going to break down and require the laborious work of removing and reinstalling the trans all over again. Any recommendations for which to get and which to avoid?
RockAuto and Autozone seem to feature TC Remanufacturing, while Autozone also sells ATC Pro King.
Transcend sells CVC & Recon.
There's also Dacco, and maybe some others.
No idea which are good and which are junk. Can't justify OEM or high-end aftermarket for this car. Are any of these good? Should I get a junkyard converter, or maybe even stick with the one the car has now?
The reason for the rebuild was no reverse, and opening up the case revealed completely worn out 1st & reverse clutch discs and badly scored plates, likely due to someone putting in an extra plate in this clutch pack that put way too much pressure on the other discs and plates and likely slipped them so that they never fully disengaged. Also, blocked cooler lines to the oil likely overheated it and made things worse.
Is there any way to tell if the current converter is bad?
