I did some researching on this forum, but didn’t find exactly what I am looking for, so bear with me if this is a repeat. I recently purchased a 2017 Toyota Tacoma Sport 4WD, access cab. Very shortly after the purchase (less than 1000 mi on the odometer), I started realizing a wind noise on the driver side, it sounds like the window is slightly cracked open and starts around 60 mph. It is really noticeable as you drive near a barrier (such as a jersey barrier along the highway) where the sound is reflected back. I first noticed a small gap in the vertical rubber molding on the door frame, where the vertical molding meets the rubber molding in the corner of the door frame. This gap was not present on the passenger side or on another Tacoma access cab I looked at. So I brought it to the dealership and had them replace the molding to remove the gap. In meantime I taped up every seam with painters tape: the seam that runs around the entire door where the door meets the frame, the seam where the window meets the rubber weather stripping on the door (the glass to rubber interface on the window itself) and then the seam around the entire access cab window (the window that does not open). I taped each seam system individually and drove the truck for some distance at 60 mph. In each case the noise did not change. Then after the dealership replaced the molding the noise also did not change. The only thing I can surmise is the door insulation is minimal at best or it is a design flaw that allows the aerodynamics to generate noise at higher speeds at the door/window seams. To say this is frustrating is an understatement after spending over $35k on a new truck. The dealership sales rep and the service rep have never heard of this issue but complaints are online. I do not chalk this up to - it is a truck so noise will be present, or refuse to hear - you have to just let it go. Certainly making me second guess my decision to go Toyota again (my previous 2002 Tacoma lasted 312,000 mi and I loved it). I have seen some complaints on the 2017 Highlander where wind noise is due to gaps in the chrome trim under the side mirror, but I don’t think that applies to the Tacoma. I had a friend drive the truck as I sat in the passenger seat and it didn’t appear to be as prevalent, but I haven’t spent much time in the passenger seat to really compare. I don’t want to just drop it at the dealer and hope for the best, so I will continue my investigation, but I am really running out of ideas. Disappointing and at a loss here, any thoughts on this are appreciated. Thanks in advance.
