Windshield wiper fluid button / pump not working
4.6K views 4 replies 4 participants last post by  92JrollaDX
I'm not sure if it has anything to do with my AC Delete or not but the button to squirt windshield washer fluid isn't working. No sound from the pump.
Could one of the connections for the ac lines have something to do with it?
Wiper's still work.
Could one of the connections for the ac lines have something to do with it? No !
Wiper's still work.
Absolutely not related. They are two different systems. Have you even looked to see if the windshield fluid container has washer fluid in it. Next check the washer pump for current.
I tested my pumps through just taking them off and connecting to the terminals on the pump itself. You can choose any method you would like. I had an issue with this once, and it was just the pump. A huge word of advice on this as well (if it is the pump you need), if you are going to pick a part it, take your broken pump with you. I found out really quickly that there are many different types of them, some have an elbow, some are straight, different size input/output holes etc. I would also take the rubber elbows, fittings etc that go to the line, trust me - just do it.
I had to go down three times when I replaced the reservoir, thinking there were just a change to the design when the facelift for the gen occurred, but boy was I wrong. I've seen more than four different styles of bottles/pumps. If you decide to go that route anyway.
Good luck.
-Kevin
