wireless carplay solution!
1 reading
9.3K views 39 replies 10 participants last post by  alanwagen
My Camry constantly had issues with the wire from the USB port to our phones. It was really annoying that It would constantly disconnect every time we hit a bump. I got a recommendation from my friend for a smart dongle that does the issue.
I bought a CarPlay adapter and I use it in my Camry. It was very easy to install. Just plugged it in and followed a couple of simple prompts on the screen. I paired it to my car in less than three minutes. Once paired, it boots carplay automatically each time I start the vehicle. It connects immediately when I get in the car and shuts off automatically after I get out.
Carplay seems to work just the same as when connected via USB. Knob and steering wheel control both work just the same as wired CarPlay. There is about 1 to 2 seconds of delay on the audio side but that's totally fine. By the time car boots up, it can jump straight into CarPlay automatically. Didn't expect it to be faster than plugging in a wire and I am pleasantly surprised by this!
The adapter is quite small and smaller than I thought it would be so it' fits nice in the center console tucked out of the way. I installed it in the center console, so its totally out of view and connects perfectly. And plugging it is also charges it. Wired also great, but there are benefits to having it wireless. No need to take the extra step to plug it in, it can sit in your pocket. Or, if you leave the phone is a bag, you don't have to fish it out.
The key is that the adapter can also charge my phone!!! This is really convenient!!! Now we get in the car and it connects automatically. I am very satisfied with my carplay adapter. Highly recommended!
Hi, i am using carlinkit 4.0, got it with $79.50 from their official store using their promotion code: NEW50
(I'm not sure if this discount code is still valid, you can try it)
I know Amazon has it too, but I've seen a lot of people saying "Don't buy from Amazon! Because Amazon doesn't have a technical after-sales team, that's why they have so many bad feedbacks! After 30 days you use, if there is any problem with the device you will go to the Amazon support, and the amazon support only suggest you to find the seller, but you will never find the seller! you are like buying a one-time device for tens of dollars..." Then I didn't dare to buy it, but carlinkitbox promised me a 30-day refund guarantee+one year Tech support + one year of free replacement(if there is any problem with their device),these are the services that only can be provided by official sellers. That is why I placed an ordered from them soon.
#14 ·
You have to be very careful with Amazon. There's a reason their stuff is so cheap...it's a lot of Chinese junk. Knockoff parts and such. Now, I'm not saying everything they sell is crap, but alot of it is just that...crap. Just be careful when you purchase from them. esearch and read the reviews with some degree of scepticism. Anyone can write anything...including the sellers. Remember...if something ounds too good to be true, it probably is.
#17 · (Edited)
When I got my Camry last year, I was annoyed that Android Auto (similar to Apple CarPlay) kept cutting out whenever I hit a bump. Figured that the heavy-duty USB cable I was using was too stiff, so I substituted a cheap thin cable that was more flexible. Problem solved.
#20 · (Edited)
@vidall What original USB cable? My car didn't come with one. Did yours? Do you think that a phone's manufacturer designs its charging cable with a bouncy ride in a car in mind? No, they expect you to use it by your bedside overnight.
The issue isn't whether the various terminals are correctly wired - the only thing that an original cable guarantees - it's that a stiff cable will not flex easily when the car hits a bump, and is stiff enough to wiggle the plug in the jack, momentarily interrupting the connection. A thinner cable is more flexible, so that's less likely to happen.
@Steven68 The advantage over a wireless connection - particularly on a long drive - is that your phone gets and stays charged. You could put the phone on a charging pad in the car - until you get tired of picking it up off the floor after hitting bumps - unless you get a phone holder that includes a charging pad.
Also, the audio link over a wireless connection uses lossy compression like mp3, while a wired connection uses PCM like on a CD, at least with Android Auto. Sure, internet radio is compressed, but why go through two levels of compression? And Amazon Music now has sound quality comparable to a CD on most albums The sound quality of the car's stereo is pretty good, so I'd rather not compromise it by using a radio link from the phone to the car.
owns 2021 Toyota Camry LE
#21 ·
He should be talking about the data cable that came with the phone when he bought the phone. Because there are many low-quality data cables on the market, there is no problem when charging, but the difference is very large when transmitting data.
In your imagination, the sound quality of the wired connection will be better than the wireless connection, but after using the wireless carplay, you will find that it is the same, at least I did not hear any difference.
#26 ·
The sound via wireless seemed less detailed - which is the defining trait of lossy compression, which throws away a lot of information that the designers of those compression schemes (like mp3) figure we won't notice, like quiet sounds close in time to a loud sound. That's how they get such extreme compression ratios, like 10:1.
I prefer FLAC ("Free Lossless Audio Compression") which works the same way as a zip file - it scans the file looking for repeating patterns and substitutes shorthand names that it puts in a dictionary at the beginning of the compressed file. On playback, the full pattern is put back wherever the shorthand is found. This lossless type of compression only yields about a 2:1 compression, but no quality is lost. This type of compression was invented in the early days of personal computing for distributing programs - where any difference between the original and final files could lead to program errors.
FLAC files can take all the tags that can be applied to an mp3, from names and titles to embedded cover art. FLAC is how I rip CDs, and is what Amazon Music uses to stream in CD-quality (which they call "HD"). It's public-domain on purpose, hence the Free in its name. As a result, most computer music programs support it, since there's no licensing fee to pay.
#30 ·
I'm a long-time hi-fi, photography, and computer geek, so I've been dealing with these kinds of things for decades. Even set up a home theater in a room in my basement.
I understand that the newest version of Bluetooth has improved its sound quality. I just find that a cheap thin USB cable serves both signal and charging needs more simply than buying and setting up a pair of wireless devices.
PS While my Camry is in a body shop I'm driving a rented Chevy Malibu (which makes me miss my Camry) which does Android Auto wirelessly. Go figure!
#33 · (Edited)
So glad to be back in my Camry - the programmer of the Malibu's electronics insisted that two connections between the phone and car - USB and Bluetooth - weren't enough, it needed to use wifi as well. This meant: (1) the phone didn't charge well because it had to power its wifi radio and (2) internet radio kept cuttiing out as the phone linked to and lost wifi hotspots it passed.
Turned off wifi on the phone, Android Auto stopped. Turned it back on and went to turn it off on the car's screen instead and was warned that this would stop Android Auto.
Why require three connections to do what one can do?
#34 ·
So glad to be back in my Camry - the idiot programmer of the Malibu's electronics insisted that two connections between the phone and car - USB and Bluetooth - weren't enough, it needed to use wifi as well. This meant: (1) the phone didn't charge well because it had to power its wifi radio and (2) internet radio kept cuttiing out as the phone linked to and lost wifi hotspots it passed.
Turned off wifi on the phone, Android Auto stopped. Turned it back on and went to turn it off on the car's screen instead and was warned that this would stop Android Auto. Why require three connections to do what one could do?
Part of the Google Android Auto. Bluetooth connections don't have the bandwidth required by Android Auto Wireless.
#37 ·
No dongle involved either car, just a USB cable plugged into the dash.
In the Camry, Android Auto is perfectly happy with my phone connected by USB and Bluetooth and does not insist on adding wifi as well.
In the Chevy Malibu, Android Auto turns on the phone's wifi and won't run at all if wifi is turned off on either device.
About the only guess I've come up with is that the Malibu's USB jack isn't a data port at all but just a 5V power jack.
#38 ·
The original poster was about this device so it does have a dongle.
