I’m not sure what others are doing, but given TSB 0034-14, my current plan is to change the transmission filter, remove the two current pan magnets, add the four new TSB Magnets (part # 35394-08010), and change all transmission fluid at 25-30K on our 2015 LE. Although the current TSB concerning the U760E transmission includes only the 2012-14 models, the 15-16 Camry transmissions are likely nearly identical with perhaps only minor internal mechanical changes and software updates. It just seems to me to be the safest approach. Everything else is done with the full fluid & filter change anyway… and more magnets can only help for the long haul. Cost at dealer is $300 plus magnets (looks like about $6 each).
U760E transmissions using the same parts:
Magnet/Oil Cleaner: Part Number - 35394-30011/New Part# 35394-08010, Quantity 4, (Fits 13-15, could not verify 12)
Transmission Filter: Part # 3533073010 (Fits 12-15)
Pan Gasket: Part # 35168-73010 (Fits 12-15)
Pan: Part #s 14-15 - 35106-06020, 12-13 - 35106-0R010
Note: I could not verify the 2016 parts via an online Toyota Parts Catalog but I would expect that they’re the same as 2015. As shown above, there are also different transmission pan part numbers dependent on year. I have no idea what the change is/was but it can’t be much since they still all use the same filters, magnets (per TSB), and pan gaskets.
Best to all, Dave
