I have a 1990 G2 4cyl engine knock when revving.
as "The Camry Man" I repaired over 300 of these G4's and the one & only last knock was the water pump.
Already tried the following on this one;
Any help would be assisting ALL :thanks:
- Listened to engine with long screw driver from ear, definitely a knock
- Pulled plug wire one at a time and found #4 when pulled = no knock
- SOUNDED LIKE THE TOP BUT GONNA PULL PAN ANYWAY
- Figured rod bearings so I pulled the pan on this G2 = EASY
- ALL bearing looked perfect , no slop ..:spy: hmmmm ???
- Pushed around on the pistons and wrist pins = all seem tight
- Brake cleaner the threads and rod nuts, applied red lock tight ,hand start & torqued to 36ft lbs final.
- inspected flex wheel bolts = tight
- Reinstall pan , added 5w30 full synthetic.. restart engine :drama:
- Still has same knock at rev unless I remove #4 wire ???
